Need some expert advice
Old Jul 16, 2017 | 09:26 AM
Barryt's Avatar
Default Need some expert advice
I have a 1998 Honda Civic DX 1.6L. It is a manual. Just yesterday I replaced the condenser fan with a new one. It wasn't too bad of an ordeal. All of the connectors only connect one way so you really can't mix up the connections. I replaced the 20amp fuse and the condenser relay. When I started the car and pushed the a.c. button, no fan. It started to kind of put alot of strain on the engine overall. It started missing and the fan acted like it wanted to cut on. I know I need to still check on connections, but off the top is there an obvious reason why? I have other issues I'll get to later, no operating to this. But I'm getting one thing at a time. Thanks for any input.
Old Jul 16, 2017 | 12:17 PM
mk378's Avatar
Default Re: Need some expert advice
Condenser fan relay could be bad. It is in the underhood fuse box. Swap it with the rear defroster relay, they are the same. When you have the relay out, look at the contacts in the fuse box for any melting or burning.
Old Jul 16, 2017 | 04:43 PM
Barryt's Avatar
Thank you for the info. After looking somemore I realized I got one of the bracket bolts mixed up. I found the bolt used for the ground wire for the fan. I tightened that clean bolt up and she is blowing cold air once again inside! Thanks again!
napa2u
Nov 24, 2015 06:24 PM
Justinmnhall
Jun 4, 2013 11:07 AM
mark458
May 3, 2010 08:07 AM
M-EJ1
Feb 23, 2005 12:32 PM
Etylorcen
Aug 1, 2001 07:24 AM
