New em1 owner
Hi. I need some help. I recently did a B18c swap on my 2000 civic siR. The wire harness I got was completely chewed up, I don't even know if it was even the right wire, so I used the sir wires. Only thing is that the B18c doesn't come with a crank sensor and something else. I also didn't get the B18c why, so I used the same ecu I had. After installing everything. The car car starts with no Problem, when the car is in neutral, I get revs bit when I put the car in gear, the car doesn't move and no rpms. I just got myself a p73 ecu (b18c ecu). And waiting for obd2b to obd2a harness. AND NOW MY QUESTION IS what is the actual Problem? Is it the ecu only or is there anything else? PLZ HELP? I don't know much bout these stuff.
