Suspension & Brakes Theory, alignment, spring rates....
Bad Lower Ball Joint - Need Opinions Fast!
Old Jul 10, 2017 | 09:57 AM
2x0's Avatar
2x0
10 Year Member
Default Bad Lower Ball Joint - Need Opinions Fast!
I finished up my tranny swap this weekend and noticed my right lower ball joint was pretty loose and felt crunchy when I moved the bolt around where the castle nut goes on. It moved very freely and kinda flopped around.
I rebooted it and put everything back together not thinking it was an urgent problem.
Drove 22 miles to work today in the car, and noticed that tire was rubbing when I hit dips in the road, it never did that before. Then pulling into work, turning at slow speeds I hear a loud creaking sound from that corner of the car. I am now wondering if that ball joint is close to failing, and whether I should risk driving 20 miles back home tonight on the highway? The steering has always felt like it pulled sometimes, but I attributed that to having no PS and 225 tires on the front.
I know it sounds stupid to risk anything, but my other option is to catch a ride home, leave my car out in the work parking lot until I can get it to the shop down the street later this week. Meanwhile my wife will bitch incessantly about how much a piece of crap my car is and how much it has cost.
So what do you think? Any way to know whether it's got some life left in it?
Old Jul 10, 2017 | 11:05 AM
Tyson's Avatar
Default Re: Bad Lower Ball Joint - Need Opinions Fast!
I think you use that scissor Jack and take a look first to see what's wrong before coming to conclusions or asking questions.
Old Jul 10, 2017 | 11:08 AM
2x0's Avatar
2x0
10 Year Member
I already know it's a bad joint, from checking everything out while I had it apart.
If I jack it up, the wheel doesn't move in or out as if it was loose, but I know that the noise is coming from the ball joint. I don't have the means to do any further disassembly or investigation while in the parking lot at work.
I am just going to get a ride home, then take it over to a shop tomorrow. Not worth the risk.
Old Jul 11, 2017 | 08:39 AM
SpeedRacerEX-R's Avatar
Just change it. They'll loan you the tool at O'Reilly's, the ball joint is ~$20. The most expensive part will be the alignment.
Old Jul 11, 2017 | 12:39 PM
Benny Honda's Avatar
5 Year Member
.......and tell your wife the car makes you happy, her nagging you does not.
Old Jul 11, 2017 | 05:46 PM
2x0's Avatar
2x0
10 Year Member
Alrighttt let this thread die already haha. I get panicky when I have car troubles that disrupt my daily routine.
The car is at a shop near my work getting a ball joint.
And believe me in this house, happy wife = happy life
B_Swapped93
17
Aug 9, 2013 05:05 PM
MechEng
Aug 9, 2011 02:13 PM
supermansdx
Oct 10, 2009 05:13 PM
hb_racer
12
Mar 29, 2002 05:30 PM
