Comparison power numbers of a G"LS"R with stock camshaft
Old Jul 10, 2017 | 07:27 AM
Z0831xiz's Avatar
Default Comparison power numbers of a G"LS"R with stock camshaft
Wanted to see who had a similar build with dyno sheets to compare to my setup to see what to expect. I searched on the dyno sheet thread but not many like mine. Heres my setup
B18C5 block & Head, heads been resurfaced & blocks been decked minimum amount.
550cc Deatschwerks injectors
320lph AEM fuel pump
Hondata S300 V2 ECU
Rywire engine harness
ITR intake manifold
AEM fuel rail & FPR
AEM true time cam gears
Skunk2 alpha 70mm TB
Skunk2 tuner 2 cams
Skunk2 alpha dual valve springs & retainers
Skunk2 LMA's
Mugen Power 4-1 high flow header
Gates racing timing belt
Cp Pistons 12.5:1 compression
BC LW H beam rods
89MM OE Stroke Crank
Golden Eagle oil jet delete
Golden Eagle Block gaurd
ATI Superdamper street.
New OE Headgasket
New OE Water pump
New OE Oil pump
New OE tensioner
ARP main studs
ARP headstuds
ARP flywheel bolts
ARP pressure plate bolts
ARP tensioner bolt
ARP Crank Damper bolt
Old Jul 10, 2017 | 09:00 AM
k20z1ej1's Avatar
Default re: Comparison power numbers of a G"LS"R with stock camshaft
Hondata S300 V2 ECU
ITR intake manifold
AEM fuel rail & FPR
Skunk2 tuner 2 cams
Skunk2 LMA's
BC LW H beam rods
New OE Headgasket
New OE Water pump
New OE Oil pump
New OE tensioner
ARP main studs
ARP headstuds
ARP flywheel bolts
ARP tensioner bolt
a hand ful of people have built ITR engines with 12.5:1 compression and tuner 2's. should make 200-220whp depending on dyno if thats what you want to know
Old Jul 10, 2017 | 01:03 PM
Z0831xiz's Avatar
A hand meaning few or plenty in trying to find a similar setup to see what all they did to compare. Im doing the tuner 2 as test cam depending how it does ill upgrade to a bigger cam
Old Jul 10, 2017 | 01:31 PM
Twin Cam's Avatar
What size pistons are you using? If 82mm, do a search for 82x89 setups and you'll find a few. I put down 220/159 with a similar setup to yours.
https://honda-tech.com/forums/all-mo...-gs-r-3256484/
Old Jul 10, 2017 | 02:10 PM
Z0831xiz's Avatar
Forgot to mention that i have 81x89mm setup you got a dyno graph whats your rpm limit
Old Jul 10, 2017 | 02:59 PM
Twin Cam's Avatar
The setup made power to about 8500.
Old Jul 10, 2017 | 03:29 PM
Z0831xiz's Avatar
I wonder if the tuner 2 wil be able to make power past 8.5k rpm for me
Z0831xiz
13
Nov 6, 2017 04:00 PM
riceboy85
51
Oct 11, 2012 03:54 PM
2point6
18
Jan 6, 2007 03:53 AM
2point6
Dec 31, 2006 10:07 AM
efit
Jun 18, 2005 11:20 AM
