Suspension & Brakes Theory, alignment, spring rates....
New rotor & break pad change causing left side wheels noisy and heating
Old Jul 9, 2017 | 06:49 PM
sunkarass's Avatar
Default New rotor & break pad change causing left side wheels noisy and heating
I changed New rotor & break pad causing left side wheels noisy and heating. What might be the cause and is it ok after driving 20 to 30 miles? or is it dangerous?
Old Jul 10, 2017 | 06:05 AM
DumpdEJ6's Avatar
I like the tuna here
Default Re: New rotor & break pad change causing left side wheels noisy and heating
Did you change both sides? Did you lubricate the caliper sliding pins with new high temp grease? I'm assuming you were able to compress the caliper piston in order to fit the new brakes on there.Take the caliper off and verify that the outer bracket slides smoothly on the slider pins. As for the noise, it's also possible that the brake pad hardware is touching the rotor or that the heat shield is bent and touching the rotor.
BIGef
Dec 23, 2012 02:57 PM
sk8shorty012
23
Dec 27, 2010 04:52 PM
vanny_david
Suspension & Brakes
Feb 22, 2010 05:52 AM
Joe 91 Accord
Nov 16, 2003 10:53 AM
DIP_SET FoReVr
Oct 6, 2003 08:58 AM
