Honda CR-V & Element 2WD & 4WD Element & CR-V
2003 CRV A/C woes
Old Jul 8, 2017 | 12:50 PM
kmoese's Avatar
Default 2003 CRV A/C woes
Hi all, my a/c compressor clutch will not engage. System has pressure in the low side (i forgot to check the high..). I get battery voltage at the relay terminals when I turn the a/c on, and I have shorted the relay terminals to the compressor clutch to manually engage, and no luck there. I figure my next step is to see if I get voltage at the connector on the compressor itself when I switch a/c on, but I feel like I'd have to pull the whole front end apart to get to it.. does anyone have a trick to get to that connector?
Thanks!
whahappened
Acura TSX
Nov 2, 2012 03:20 PM
sonnyny
Jun 10, 2012 10:07 AM
Mackln308
Jul 30, 2010 11:34 AM
19integra91
Jun 12, 2008 06:02 PM
Accordn95
Jun 25, 2007 04:25 PM
