Transmission & Drivetrain Gearboxes, Differentials, Clutches
Swapped tranny, now clutch cable too short?
Old Jul 7, 2017 | 05:42 PM
2x0's Avatar
2x0
10 Year Member
Default Swapped tranny, now clutch cable too short?
I recently put a new junkyard tranny in due to blowing my differential. Tonight I was trying to hook up the clutch cable, and it's as if it is way too short. Even with the adjustment nut all the way up on the cable, the clutch fork on the tranny has to lift all the way up for me to get the cable on.
I replaced an A1 tranny and it's identical to the old one, where the clutch worked fine. How can this be happening?
In the pic below, I have the cable on the clutch fork with it lifted all the way up (clutch disengaged) and you can see how far off from the mounting holes I am with the bracket. What could I be missing? The fork should be all the way down when the pedal is not being pressed.
Old Jul 7, 2017 | 06:30 PM
2x0's Avatar
2x0
10 Year Member
Default Re: Swapped tranny, now clutch cable too short?
Ok maybe I am mistaken. I've got a stage 5 clutch, how much force should it take to lift the fork once it touches the pressure plate? Would I be able to do it by hand or no?
Vash121991
May 22, 2012 12:47 AM
jp1
Feb 16, 2006 10:54 AM
NCchris
Aug 22, 2003 06:38 PM
.nate
Sep 12, 2002 12:47 PM
