Does any one else have a saggy rear bumper???????
Old Nov 10, 2002 | 08:22 PM
integraautox's Avatar
Default Does any one else have a saggy rear bumper???????
Ok I am notices that my rear bumber is begging to sag on my 94 integra by about 1/4 inch it is kind of annoying. I have no clue why it is doing this. Does any one else have this problem or no how to fix it. I really want to get the tight seal back. Thanks
Old Nov 10, 2002 | 08:25 PM
greasy007's Avatar
From: bustanut inside y0 eye, to show yu where i come fr
Default Re: Does any one else have a saggy rear bumper??????? (integraautox)
i kinda have that problem too, this fat girl sat on it once, i didnt think nothing of it untill i looked at it closer, i was like FAWK.
Old Nov 10, 2002 | 08:28 PM
piatl7il77's Avatar
Default Re: Does any one else have a saggy rear bumper??????? (greasy007)
hahah now i have to go and check if my rear is sagging. Thanks
Old Nov 10, 2002 | 08:37 PM
Aaron M's Avatar
Default Re: Does any one else have a saggy rear bumper??????? (piatl7il77)
i do, only after some1 bumped it
Old Nov 10, 2002 | 08:40 PM
mattL's Avatar
i was in a rearend and since then its got a bit of a gap, especially where it matches up to the rear quarter.
Old Nov 10, 2002 | 08:47 PM
Default Re: Does any one else have a saggy rear bumper??????? (mattL)
ya thats where mine is to near the rear quarter pannels only on the drivers side and a little on the passenger but not much does any one now how to fix this or is the only way a new rear bumber.
Old Nov 10, 2002 | 09:00 PM
Pat's Avatar
Pat
both my tailights and bumper are kinda sagging on a 98
Old Nov 10, 2002 | 09:09 PM
bocian's Avatar
Default Re: Does any one else have a saggy rear bumper??????? (Pat)
damnn ei thought i was the only one! mine sags too i know it does get on my nerves like a ****.
lets face it integrras have lazy asses.
Old Nov 10, 2002 | 09:32 PM
gsrstyle's Avatar
my rear used to sag. what you do is take off the rear plastic panal, that covers the rear tail lights. you might also have to pull back on the side plastic panals too. but anyways you will see at the bottom of the trunk, 4 or 5 nuts. and that holds the bumper. oh yeah, dont forget the bottom clips, located right under the bumper near the license plate and the screws in the rear wheel well. after i took off all the clips and nuts, i had someone hold up 1 side while i put the nuts back on.
my friend suggested that i should of used a jack, to jack up the bumper, so the gap would be even smaller. ha i think i will do that since my license plate bulbs died on me.
Old Nov 11, 2002 | 01:14 PM
XxCarChickxX's Avatar
Default Re: Does any one else have a saggy rear bumper??????? (gsrstyle)
bump
Old Nov 11, 2002 | 02:57 PM
jdmb18c's Avatar
Default Re: Does any one else have a saggy rear bumper??????? (XxIntegraGurliexX)
My rear one is fine but my front is sagging. It no longer makes a tight fit with the hood. I have a 95. Is there a fix for this problem?
Old Nov 11, 2002 | 05:16 PM
IntEGNYC's Avatar
Default Re: Does any one else have a saggy rear bumper??????? (jdmb18c)
Body bags in the trunk, yeah
Old Nov 12, 2002 | 02:01 PM
GSRaCeRbOI's Avatar
my friend had a problem w/ really bad sagging of the front bumper on his Acura Legend.. he took it to a body shop and they told him its common on Acura's and that the bumper would have to be removed so that they can replace the plastic mounts that hold the bumper up... not sure if this applies to the integra.. but this is what the guy at the body shop told my friend for his Legend
Old Nov 12, 2002 | 02:26 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Does any one else have a saggy rear bumper??????? (GSRaCeRbOI)
I don't see how the front bumper could be sagging by the edge of the hood, since the upper edge of front bumper sits on the radiator support, sandwiched between the radiator support and that black metal bar that goes over the bumper cover.
Old Nov 12, 2002 | 03:06 PM
Jay J's Avatar
Prince of Zamunda
has your car been in an accident or rear ended?
forever
Old Nov 12, 2002 | 04:18 PM
GSRaCeRbOI's Avatar
Default Re: Does any one else have a saggy rear bumper??????? (PatrickGSR94)
this was on an Acura Legend..not integra.. and thats what the body shop guy told him...
PowerLeg
Nov 1, 2010 10:05 PM
envision
Jan 26, 2008 05:58 PM
Dateggy21
Jan 20, 2008 05:17 PM
Tommy_Gunns
Aug 10, 2002 09:23 PM
