Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2011 FA5 A/C problem
Old Jul 6, 2017 | 08:28 AM
spenceyd's Avatar
Icon4 2011 FA5 A/C problem
I've read forums and what not on what could be wrong.
But anyway, I have an FA5 DBP that I just got about a month ago and I have noticed that when I am sitting at a light or parked with the A/C on, it does not blow cold air; however, when I get to about 2k RPM it starts to blow cold air. I have it on MAX A/C and recirculating air button is on.
I am thinking it could just need a recharge on the system. Any other opinions?
BTW, the compressor does come on and the fan does as well.
Old Jul 6, 2017 | 11:30 AM
nsxmatt's Avatar
Default Re: 2011 FA5 A/C problem
I would check to see how much refrigerant is in the car. These cars have a large dash area and not much r134 in the system and on hot days don't blow very cold at idle.
Old Jul 6, 2017 | 04:03 PM
spenceyd's Avatar
How do I check the refrigerant levels?
Old Jul 6, 2017 | 06:39 PM
holmesnmanny's Avatar
It's likely you have a leak. You can't really check the level unless you recover the refrigerant. I would pick up a can of refrigerant with leak detector and a uv glasses with light kit and add about half a can and drive it around. Check for leaks. Recover refrigerant, fix leaks. Evacuate for 30 minutes. Recharge to spec.
Old Jul 7, 2017 | 06:40 AM
spenceyd's Avatar
Why do you think I have a leak? The A/C gets cold when my RPM's are up. If it never got cold then I could see that it could be a leak, but this problem has been occurring for weeks and I haven't had time to get it looked at professionally.
Old Jul 7, 2017 | 07:59 AM
nsxmatt's Avatar
When the RPM's are up the compressor is working harder plus there is more air moving over the condenser making the system operate easier. When it's at idle and the compressor is barely tuning over and you are low on r134a then it won't cool as well.
Old Jul 7, 2017 | 06:36 PM
91boz's Avatar
Check to make sure your ac condenser fan is running. This is the passenger side fan right behind the radiator. If the fan does not run the condenser will not cool at idle but will when you drive the car because air will flow thru it.
Old Jul 8, 2017 | 05:19 AM
spenceyd's Avatar
If I am parked and press the gas without moving, the air gets cold.
Old Jul 8, 2017 | 09:58 AM
spenceyd's Avatar
Just noticed that when the A/C fan is blowing super fast and moreso slow-medium speed it is cold. This could be because my car was in the shade, but I'm not entirely sure.
boilerbob
Nov 11, 2018 12:36 PM
xxstreetracer605
Mar 7, 2010 03:05 PM
GraphiteMW
Oct 30, 2006 04:29 PM
SLATER97EX
Nov 17, 2005 09:29 AM
JasonBlackEJ1
Mar 17, 2003 12:25 AM
