oem brake lines
Old Jul 6, 2017 | 07:30 AM
brokebuilder's Avatar
Default oem brake lines
can i use my stock brake lines on a aftermarket brake booster delete? (first time doing brakelines) will be on my 95 civic
Old Jul 6, 2017 | 08:52 AM
hondaracing84's Avatar
Default Re: oem brake lines
The issue you'll run into is the stock brake lines have two lines coming off the master cylinder and brake booster deletes only have one outlet. So you'll have to have the one line come off the brake booster to a "T" then those two lines into your prop valve. After that, I think you'll be good.
But honestly, you should just do a whole new line setup. Like the kits sold at Chasebays.com
boostedjd
Dec 5, 2018 05:00 AM
padre2/3/11
Suspension & Brakes
Mar 31, 2013 02:10 PM
uses0ap
Sep 21, 2008 08:19 PM
nickzed20
Welding / Fabrication
Apr 28, 2005 10:36 PM
