Might be a stupid question about ground wires...
Old Nov 10, 2002 | 07:21 PM
kay_animation's Avatar
Default Might be a stupid question about ground wires...
Are engine ground wires really a performance mod. Do they help performance wise or is it just an excuse to add some colored wires to your car? Please help...
Old Nov 10, 2002 | 07:25 PM
97hb's Avatar
Default Re: Might be a stupid question about ground wires... (kay_animation)
Might be worth a hp or 2. If you know how to hook up sterios, then you could probably make your own
Old Nov 10, 2002 | 08:51 PM
Loco Honkey's Avatar
They'll help the car start easier and idle a little smoother if your ground wires are really screwed up.
Old Nov 10, 2002 | 08:55 PM
spoon-ej1's Avatar
From converstaions I've had with my friends and some of the guys on this board, ground wires don't add HP (def not) but may reduce the chance of a poor ground "robbing" performance.
A bad ground will cause an amp to deliver a noisy and weak signal. However a strong ground will let the amp send a cleaner and stronger signal that help the amp live up to it's potential.
The same can be applied to your motor / electrical system.
Old Nov 11, 2002 | 12:43 AM
Touch's Avatar
article is in december Import Tuner.
Old Nov 11, 2002 | 05:35 AM
skhonda's Avatar
Default Re: Might be a stupid question about ground wires... (Touch)
They make real HP gains, and in some cars a suprising increase in hp. (like 7 hp)
Old Nov 11, 2002 | 05:37 AM
Hammett's Avatar
Default Re: Might be a stupid question about ground wires... (skhonda)
Yea. I saw that too. they had dynochart to proof.
Old Nov 11, 2002 | 06:50 AM
SPORT INJECTION's Avatar
weren't they the Hyper ones?
Old Nov 11, 2002 | 07:27 AM
Doctor CorteZ's Avatar
I hope you arent serious.
I wouldnt listen to them regarding anything , worst mag EVER.
Old Nov 11, 2002 | 12:29 PM
delslow94's Avatar
i just put on a set this past weekend. i did a diy setup that grounded out the block the head the intake manifold, distributor, and water temp ground point to the battery. from what i noticed it worked well. i had a lumpy idle for no reason and it cleared it up. the car revs smoother and i have noticed some mid range power when you get on it. My headlights seem to be brighter and i did notice the dash lighting is much brighter along with my stereo's face plate. i am going to add more grounding points soon like the alternator, ecu and other common grounds in the engine bay to maximize any potential. good mod here are some links i found that i derrived locations for grounds at http://www7.plala.or.jp/daisy9/car/t...earthing2.html
http://www.rakuten.co.jp/kong/435432/455709/
good luck guys
Old Nov 11, 2002 | 01:01 PM
fire7882's Avatar
Default Re: Might be a stupid question about ground wires... (delslow94)
do you need to ground everything to the batery, or do the grounds need to go to the frame.
Old Nov 11, 2002 | 01:07 PM
lilxvtecxpwr's Avatar
Default Re: Might be a stupid question about ground wires... (fire7882)
i made a post about this the other day about the sun's automobile ground wires but just got negative responses.
https://honda-tech.com/zerothread?id=329400
Old Nov 11, 2002 | 02:15 PM
Archidictus's Avatar
Unceasing Measure
they need to go to a ground...it doesn't matter if it's the battery, the frame, or the earth.
Old Nov 11, 2002 | 02:20 PM
fire7882's Avatar
Default Re: Might be a stupid question about ground wires... (Archidictus)
That is what i thought but some people will run a wire from one side of the engine bay to the other and connect to the battery. Why didn't they just connect to the frame?? Is there an advantage to this or are all grounds created equal?? Thanks
Old Nov 11, 2002 | 03:54 PM
Bigjon
Guest
Posts: n/a
Not all the possible ground points are equal. Although I doubt it is as important to get equal potential grounds with the motor and electrical system as with an audio system. The way to check it is to get a multimeter and measure the voltage from the posative point on the batter to whatever point you are using as a ground. The voltage should be the same as if you were measuring from the pos terminal of the battery to the negative.
JDMSi92
Audio / Security / Video
Jun 13, 2005 08:37 PM
THE94GSR
May 28, 2003 08:53 AM
thaiphob
Oct 28, 2002 08:19 PM
GSR-REX
13
Sep 6, 2002 07:27 PM
