I live in turkiye istanbul and I want to share with you the swap project that we are preparing for a year. If there are new ideas about what to do after the year, it will be great. Write your thoughts pls.
Case
1994 EG5
Carbon fiber rear door
Type S Porya 5 x 112.4
Ebc 282 mm air cooling brake discs
Ebc on rear brake pads
EG carriers
Energy Suspansion komple bushing
Energy Suspansion Travers Wedges
Skunk2 rear balance
ASR medium carrier
DC2 Oem Tower Magazine
K Tuned Coilover crew
Jdm Headlamp Signal and Stop Timer
Mugen ten bumpers
Spoon rear spoiler
Ek9 5x112.4 Wheelset
Toyo Proxes T1R 195/50/15 Tires
Side PhotoSmile
Engine
B18C JDM TypeR
82 mm Wiseco 12.7 cr Piston set
SpecR Oem Rods
SpecR crank shaft
Acl Rod&Main Bearings Kit
Oem SpecR cylinder Main studs
Supertech Guide
P73 SpecR Head
Skunk2 Ultra Street Series intake manifold
70 mm Black Series throttle body
70 mm Intake kit cork air filter
Aem High-volume Fuel Rail ( Black )
550 cc RC injector kit
Tomei fuel regulator
3 "4-2-1 Hytech Headers
Brian Crover Dual valve springs/Titaniun Retainer Kit
Skunk2 Cam Gears
Skunk2 Pro Stage1 Cams
Nissan CAS EPM
Wolksvagen R8 Coil
Ebay product aluminum radiator and Slim fan.
Samco silicone coolant hose set.
ACT Stage 3 6 puck clutch kit
Ultra light flywheel
NISSAN CAS EPM / WOLKSWAGEN R8 COIL
Transmision;
S4C transmision
4.7 M factory final drive
1.vites M factory 3.070
2nd shift S4C 2.105
3.vites S4C 1.458
4.vites S80 1.034
5.vites S4C 0.848
ECU :
Ecu Master (EMU) ECU
Bluetooth connection part
Oil pressure and temperature sensor
Wideband sensor
Egt sensor My tuners eyes 🙈
This Dyno sheet
For New cams
Inner
DC2 GSR dial
DC2 Integra TypeR steering wheel
DC2 integra TypeR Recaro front seats.
DC2 integra TypeR rear seats.
K tuned gear and gear ****
EG6 Center console
Me and my dc2 recaro seats...
Lastly, I wanted to write a change that we did in addition to these ...
I removed the Tape and Air Conditioner control panel located in the center console of my car from there and put a samsung tablet which can be attached to the area and can be removed in a 9.7 "line.
Cd player and climate control panel on the EG6 console.
What can I do with this tablet?
From what I've seen with the EMU application I have come up with what you see in mind (AFR / IAT / ECT / TPS / EGT / OIL PRESS / MAP) you can see from here, so I got rid of that big display density.
The sensors such as the Wideband sensor / Egt sensor / EMU oil pressure sensor have been inserted directly into the brain to see the instantaneous data of the vehicle and the limitors have been installed. We have enabled the brain to correct itself regardless of whether the AFR is open, in which city or on the varex exhaust cover. EGT Limitor was put in order not to harm.
K Tuned - EG6 Konsol - Samsung tablet.ECU MASTER On the road bosphours bridge from asia side to europe side in istanbul.
Re: MY 1994 CIVIC EG HATCH B18C SPECR SWAP PROJECT
Originally Posted by ardaaykan
Hello to everyone,
Thank you for reading...
Hello! Looking for some information to implement a tablet in my '92 Civic EG I found your post and I love the work you did, it is an awesome project. Congratulations.
Do you have any other photos so I can see how you attached the tablet to the dash? Also how did you do all connections to use it as a head unit?
