Honda CR-V & Element 2WD & 4WD Element & CR-V
2005 CRV Rear Brakes
Old Jun 26, 2017 | 06:11 PM
Michael Roesler's Avatar
Default 2005 CRV Rear Brakes
Rear brakes will not bleed, period. No issues with front brakes. I disconnected the flexible hose from caliper and from the rigid line in the rear wheel well and used compressed air to blow it out. Thick jelly-like fluid came out. Reconnected everything and still no change with pedal or getting anything out of the hose at the bleeder nipple. Followed the hard lines under the driver's seat area, where they disappear into the under body. Where do they come out, so I can repeat this process further up the line? I assume the rear lines are clogged somewhere?
Old Jun 27, 2017 | 09:35 AM
UK-Kev's Avatar
Default Re: 2005 CRV Rear Brakes
UK Spec – Brake pipes from rear go into a four way union located just under the bulkhead and then to the ABS pump.
Kev
rajan
Nov 2, 2016 06:01 AM
EKSedAndy
Apr 30, 2008 04:37 PM
743power
28
May 29, 2007 02:54 PM
aut0tek
May 1, 2007 09:26 PM
hybridbook
Jun 12, 2003 10:18 AM
