i ave h23a vtec engine in my honda prelude , i have tdc code so how to clear tat code
how did you install it?
Originally Posted by Prelude1897
This type of swap has been done several times and plenty of threads about it, cause I've actually done thus swap for several people. I hope you still have your original ecu. Here's a list of what you needed to swap from your old motor to this motor in order to keep it all as if it came in the car factory
-intake manifold
-dizzy
-ignition coil
-oil pump
-crank sensors
-motor harness
No need for any extra wiring or special ecu. If you swapped these parts over, car would run normal.
-intake manifold
-dizzy
-ignition coil
-oil pump
-crank sensors
-motor harness
