Ac / Engine Vibrations
Old Jun 20, 2017 | 07:37 AM
jorge74's Avatar
Default Ac / Engine Vibrations
Hi trying to figure out why the engine vibrates a lot when i put On my Ac on my 97 Civic with Ac off its fine . Iv changed out all Mounts still no luck the vibration resonates thru the steering and all the way to the muffler. Any ideas were should look?
Old Jun 20, 2017 | 07:49 AM
mk378's Avatar
Default Re: Ac / Engine Vibrations
Make sure the condenser fan works. If the condenser overheats the pressure rises and the compressor will put a lot of strain on the engine. Same thing happens if the system is overcharged with refrigerant or oil.
The idle rpm should increase slightly with the A/C on. If it drops, you may need to clean the IACV or even open up the air screw.
Old Jun 20, 2017 | 08:07 AM
jorge74's Avatar
The condenser fan works fine and the idle sits at 600rpm when off and 900rpm when on and it stays steady there. My first thought was mounts thats why i changed them but that didnt help
dawalace
Honda CR-V & Element
Aug 18, 2017 04:45 AM
googlejohn316
Aug 8, 2017 07:12 AM
Schultzie
Aug 14, 2008 11:22 PM
bibong
Mar 20, 2007 06:33 PM
whitenameseboi
Jul 14, 2004 10:11 PM
