CRX 89/OBD0/B16A/PR3 - CODE 4
Hello guys , here is the story :
I change the connecting coolant pipe today because of leak , I plugged everything back it , I got a check engine and wanted to check it out , it was 23 ( knock sensor ) , I forgot to plug it , plugged it back and no more code.When i was next to the ECU , I moved the wires a bit and the engine almost stalled , I moved it again a bit more and the engine shut off.Now i have a Code 4 - Crack angle sensor - I can't rev more then 3200 , but the engine doesnt shut off anymore when I move the wires near the ECU.I disconnected the battery and touched the positive and negative together to reset the ecu , I took out the clock fuse inside and put it back , I took out the ECU fuse and put it back too but I still get the same code.
