My wheel/tire combo...
What do you guys think:
Gunmetal Rota Subzero, 16" x 7", 14.5 lbs
215/45ZR16 86 AZENIS MAX PERFORMANCE FALKEN
mounted, balanced, and shipped for $974?
This is my car now...
Steel Grey is a great color. I so wanted to go with the 215/45/16 azenis but needed a tire to get me through the wet summers here in Colorado. Good choices in tires and wheels.
Steel Grey Subzero's gets my vote.
The Grids look really cheap.
[Modified by Understeer, 6:53 PM 11/10/2002]
I plan on driving with the stock GSR michilins....
If I feel something really bad happenning when/if snow hits, ill get something thats more for snow and keep it on the gsr wheels. I got a few sets so that isnt a problem.
What do you guys think, should I get the cheap combination subzero's? or step up to some SSR Competitions that are gunmetal with a polished lip?
Like in this picture: http://www.geocities.com/dj_spek99/dcivic.jpg (you might have to open another window to get it to work)
or
or
the only negative thing about them that i see is their center cention seems kind of boring and their price is also pretty high.
opinions?
[Modified by integra-modder, 10:56 PM 11/10/2002]
or
or
opinions?
SSR comps are sick wheels but you can't compare the rotas to the SSR's. They cost like three times the amount. If you can afford the SSR's, get them and treat they good.
also, which are better, steel gray or gunmetal?
You could get the formula-1 SSR comp knockoffs...
15lbs in 16X7
12.5lbs in 15x6.5
There was a groupbuy for 16's with 215/45/16 azenis for like $950 going a while back.
15lbs in 16X7
12.5lbs in 15x6.5
15lbs in 16X7
12.5lbs in 15x6.5
15lbs in 16X7
12.5lbs in 15x6.5
konig, rota, and Commodore there all in the same gang....all 3 come from the same factory in the Philippines.......they make good Imitations ...........just my 2 cents
I know JP got a bronze set on his white teg, they look pretty sweet...i bet they'd look nice. some WRX's run this setup...
more pictures: HERE
Are those 17's on the lude? And are you refering to the estesa's being good tires or the aziens?
more pictures: HERE
what do you guys think, final choice?
-steel gray 16" rota subzero's
Wheel Sizes: 16x7" +40 offset -14.5lbs
Steel Gray
16" $500/set with FREE Shipping!!!
OR
-black rota slipstreams with polished lip?
16x7" +40, or 45mm offset -13.5lbs
Savannah Gray with polished lip
Steel Gray
OR
Hey on that white teg, what size are they? They look like 17's with a slight drop.
Here's a prelude with 17 bronze subzeros. This should give you an idea of how bronze will look like on black.
