Troubleshooting: lower rpm power loss, regains some power at WOT
Old Jun 12, 2017 | 06:12 PM
Teggy_DB7's Avatar
Default Troubleshooting: lower rpm power loss, regains some power at WOT
i have a 1998 db7 integra with a B18b swap . My problem is that it will randomly lose power in low rpm then slowly gain the power back if I slam the pedal to the floor . Already changed plugs and wires and injectors/fuelrail . seems to only do it when the car is at temp . Any tips ??
Old Jun 14, 2017 | 11:21 AM
beeza's Avatar
Default Re: Troubleshooting: lower rpm power loss, regains some power at WOT
Hmmmm,sounds a bit like the valves aren't seating/sealing properly due to carbon build up??
Might be worth squirting some water through the throttle body to clean the upper head.
Check tps voltages.There's a diy on here by a nice guy.
bmxtrev
May 30, 2012 10:21 AM
civicvtec44
May 16, 2009 09:58 PM
b18bvudoo
Jan 17, 2002 01:39 AM
