p28 chipped ecu for a b16a3(p30)
Old Jun 12, 2017 | 04:11 PM
Vladglad's Avatar
Default p28 chipped ecu for a b16a3(p30)
hey friend of mine has a Eg with a b16a3 swap in it i believe its from the USDM del sol ? anyways he is
planning on getting a chipped p28 ecu from HAmotorsports and got some question about the base maps and what options to add on
from what i could tell when i checked the car out seems like the o2 is wired and and so is Vtec it currently has a p28 Non chipped which runs the car like crap
Socketed OBD1 P28 ECU with Custom Basemap Chip Package|HA Motorsports << thats the ecu
and what to add on
1. do i need too enable the knock sensor for the B16a3 ?
2. what type of o2 sensor is required ? if you click on the link it has two options for the o2 sensors i have no
idea which one is the right one to keep and which one needs to be disabled
let me know
Thanks
Old Jun 12, 2017 | 07:45 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: p28 chipped ecu for a b16a3(p30)
Knock sensor DISABLED (The P28 ECU does not have the circuitry for a knock sensor, so leaving it turned on or active in the software creates an MIL engine code that cannot be repaired without reprogramming the chip)
O2 Sensor ENABLED - Closed Loop operation
O2 Heater ENABLED - assuming you are using the 4-wire O2 sensor found in most OBD-1 engine management systems... DISABLE the O2 Heater circuit if you are using a single wire O2 sensor up front on the engine header very close to the cylinder head.
Old Jun 13, 2017 | 03:29 PM
Vladglad's Avatar
thanks for the input cleared alot of things up for me
AztecEGhatch
Aug 7, 2011 09:26 PM
systemoverload
Dec 11, 2005 10:09 AM
importboi22
Nov 18, 2004 07:53 AM
SETI20
Aug 17, 2004 11:57 AM
lilxvtecxpwr
Aug 19, 2002 10:18 AM
