what do i need to tubo my soch zc twin carb
Old Jun 9, 2017 | 04:55 AM
turbotecha's Avatar
Default what do i need to tubo my soch zc twin carb
honda zc 1600 soch twin carb what do i need (mainly carbs never done carb+t) accept the turbo got a gt2056v ??
Old Jun 9, 2017 | 08:10 AM
Pro-SeriesFab's Avatar
Default Re: what do i need to tubo my soch zc twin carb
It depends on whether you want to do a draw-thru or a blow-thru setup.
The blow-thru has less lag, is generally easier to tune, and is safer but you are required to have a boost referenced regulator to ensure the fuel doesn't get pushed out of the bowls as the pressure increases from the turbo.
Draw-thru is easier to setup but you still ideally need boost referenced power valves and there's some work involved in making a blow off valve setup work.
mrchris1979
Oct 17, 2005 01:39 AM
zccrx
Feb 17, 2004 12:36 PM
91hatchcivic
Sep 11, 2002 12:23 PM
