Suspension & Brakes Theory, alignment, spring rates....
how to know front disk need to replace?
Old Jun 8, 2017 | 04:42 AM
connguyen's Avatar
Default how to know front disk need to replace?
need to check the length of disk
Old Jun 9, 2017 | 10:54 AM
egsleepercivic's Avatar
Default Re: how to know front disk need to replace?
the minimum thickness will be stamped on the rotor, you need a caliper to measure it, you can get a cheap caliper from harbor freight, if you find the coupon should be about $10
https://www.harborfreight.com/6-inch...per-47257.html
or if you take it somewhere to get turned they will measure and tell you if it needs to be replaced
Old Jun 11, 2017 | 07:50 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Measure? Take somewhere to be turned??
Rotors are like $10-20 each. Live your life.
Old Jun 12, 2017 | 01:48 PM
TypeR_Tony's Avatar
Usually cracking, grooves.....signs that make the rotor look like there's something wrong is usually a good rule of thumb that they need to be replaced.
If your concerned and not sure just replace them they don't cost much. Better safe then sorry
hatchbackjo01
May 16, 2010 05:07 PM
skater5067
Jan 23, 2008 08:30 AM
accrd18
Mar 27, 2006 07:11 PM
LordoftheAccord
Mar 20, 2003 11:18 AM
irdprelude
Jan 20, 2003 04:02 PM
