I NEED AN EG ELECTRICAL GURU
Old Jun 7, 2017 | 04:19 PM
keeganeli's Avatar
Icon3 I NEED AN EG ELECTRICAL GURU
Hey guys,
So, my car starts and then won't continue to run after about 5 seconds. It'll start right back up like there isn't a problem. I have sourced the problem to something is cutting power to the fuel pump. I can read voltage when the system primes then for about a second once the car has started. Buttttttt, the weird part is if I stick my probe into the backside of the pinout of terminal 7 on the main relay I'm reading 13-14v till about a half second after the car dies. So, then I thought "mhmm maybe the wiring from the relay to the pump has a fault or something." Nope, thats not the case if I unplug the main relay and stick a wire into the pin then take the other side of the wire to battery the fuel pump runs no problem.
P.S. I have a CEL code for the oxygen sensor but that shouldn't cut power to the fuel pump....
Old Jun 7, 2017 | 04:29 PM
keeganeli's Avatar
Default Re: I NEED AN EG ELECTRICAL GURU
Also, the car runs fine if I manually supply power to the fuel pump. Oh and my under hood fuse box is internally falling apart I have to use a C clamp to get fuse #31 to get a connection -____- The main purpose of this thread is to find out if by buying the Rywire stand alone (race) harness will fix my problem or if it'll still be there.
https://www.rywire.com/product-p/b-sub-race.htm
The link above is to the rywire stand alone harness.
Old Jun 7, 2017 | 04:36 PM
mk378's Avatar
First off replace that fuse box. Maybe you are losing power to the main relay from the fuel pump fuse.
I suppose it would work to replace the whole system with rywire but that would cost several hundred and you really don't need to second-guess the Honda engineers.
Old Jun 7, 2017 | 09:12 PM
NotARaCist's Avatar
I never narc'd on nobody!
Diagnose before throwing parts at it. Find a friend with an ECU you can borrow and try. Barring that, find one in a junk yard, buy it, use it, and return it if it doesn't help.
Old Jun 8, 2017 | 10:27 AM
keeganeli's Avatar
Well the thing is the car is strictly a track car so I don't really need all that extra wiring as I just need the motor run and brake lights. So, replacing the fuse box would be sort of pointless when I am just going to get rid of it anyways. My goal to is to make sure the problem isn't a result of a bad sensor or if the ecu is receiving a bad signal.
Old Jun 8, 2017 | 10:30 AM
keeganeli's Avatar
I know forsure it isn't the ECU because before I swapped in my z6 I had a fuel pump issue as well (a little different) with my b7 and I had replaced the ECU 3 times because I was told it was the ECU. Well again this is a new ECU and still a fuel pump problem.
Old Jun 14, 2017 | 08:31 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Check this: https://honda-tech.com/forums/honda-...-fine-3156201/
My car said it was a Code 1 Oxygen Sensor, but that was wrong. Ultimate cause was a Code 43 - Fuel Delivery. Have you tried a different fuel pump?
SPUNKYMUNKY
11
Mar 27, 2015 03:58 PM
2fast4urass
Feb 18, 2010 08:21 PM
ALL MOTOR DA
35
Aug 18, 2006 09:44 PM
jvans04
Jul 24, 2005 04:49 PM
Evil DOHC
10
Feb 9, 2005 06:48 AM
