b18c type r tune up?
Old Jun 7, 2017 | 04:06 PM
eddie7978's Avatar
Default b18c type r tune up?
so i plan on getting a b18c type r motor i need to do a tune up when i get it.. so would the spark plugs, wires, cap and rotor all be the same as the b18c5 motor? i'm asking because the jdm motor has higher compression..
Old Aug 9, 2017 | 03:38 AM
Chrisxnj's Avatar
Default Re: b18c type r tune up?
same stuff as a gsr i believe
Old Aug 9, 2017 | 09:08 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Yes, the spark plugs, wires, cap and rotor button are the same as a USDM ITR... as well as a USDM GSR.
Old Dec 20, 2017 | 02:03 AM
eddie7978's Avatar
the spark plugs are different
Old Dec 20, 2017 | 08:46 PM
JRCivic1's Avatar
10 Year Member
Community Builder
For a stock replacement...the electrode material and plug gap is technically different... true. But you can screw a GSR spark plug into the ITR spark plug hole. Now, if you have say a 400 wheel HP turbocharged GSR and a 400 wheel HP turbocharged ITR... it would be the same plug.
Old Dec 21, 2017 | 03:08 AM
NVturbo's Avatar
O.G. triple O.G.
OP, if you're referring to a ITR motor swap, replace the usual parts such as water pump, timing belt, etc. You can always replace the spark plugs and stuff after the fact.....when the engine is already in.
twentyhurtz
Feb 19, 2009 05:29 AM
gsr96cx
Jul 17, 2008 07:21 PM
wizzards581
Oct 27, 2003 06:47 PM
TypeR 599
Sep 4, 2002 11:13 PM
ActiveAero
Sep 26, 2001 10:56 AM
