Hello guys, just picked up a new project, ebay turbo boosted b18c1, without a radiator or fan, was planning on buying one of those half radiators and angling it towards the motor from the left side of the engine bay but wasnt sure where i could get hosing to fit the radiator to connect it to the motor. the radiator is supposed to go on that metal bracket to the left of the exhaust and wastegate
Samco and a couple of other companies sell hoses specifically for the B swapped cars, or you can simply use (IIRC, it's in every B swap guide) 90-93 DA hoses cut to size. Spacing wise I'd ditch that bracket til I knew I could use it, and maybe even investigate the Skunk2 half-rad designed to fit a B swapped EF, seeing as your dump tubes don't leave much room for a normal Del Slow unit.
I have skunk 2 hoses that came of a b series turbo crx I got from a member and I wont be using them after all because of my AN
fitting set up my fabricator is doing lmk if interested
Yeah they have cheap B series radiator hosing on ebay for like 40 bucks so i might just get me that and cut to size lol
