Blue top?
Old Jun 6, 2017 | 12:00 PM
nick/lude's Avatar
Default Blue top?
Wanting to replace a blown black top 2.2 with a blue top from Japan what modifications need to be done to make this work in 1998 Prelude?
Old Jun 6, 2017 | 07:49 PM
98__SH's Avatar
Default Re: Blue top?
Check out this thread!
In terms of just slapping in a (hopefully) known good engine, most people put an H22A4 oil pump on it and run all USDM ignition components, since most people use the left hand drive harness from their car, not the one off the engine.
If this is your first swap prepare to be a little overwhelmed at first, but it's all good
https://honda-tech.com/forums/honda-...tions-2341343/
Old Jun 6, 2017 | 08:48 PM
TimiK's Avatar
see that it would be also wise to new all the seals and gaskets there + timing components + clutch
Originally Posted by Prelude1897
This type of swap has been done several times and plenty of threads about it, cause I've actually done thus swap for several people. I hope you still have your original ecu. Here's a list of what you needed to swap from your old motor to this motor in order to keep it all as if it came in the car factory
-intake manifold
-dizzy
-ignition coil
-oil pump
-crank sensors
-motor harness
No need for any extra wiring or special ecu. If you swapped these parts over, car would run normal.
VTEC_1229
Jul 29, 2016 10:44 AM
madmike84
16
Jan 22, 2009 10:35 PM
Subtle
Feb 10, 2002 12:20 AM
