I have for sale this 1999 Honda Civic EX. It is from South-Carolina and has seen 1 winter in Michigan. It has no rust and the body and paint are original.
- Runs 13.7xx 1/4 mile @100 mph on street tires
- Compression on each cylinder is between 185 psi and 190 psi
- Castrol Edge synthetic oil, changed every 3000 miles
It is working perfectly and is modified with the following list of components:
Chassis:
- Koni Sport Dampers
- H&R Sport springs
- Rear subframe brace
- Rear 24mm Antiroll bar
- König feather wheels 15 x 6.5
- Toyo Proxes R1R 195-50r15 Tires
- Front and rear Acura Integra disk brakes
- Honda CR-V master cylinder and booster
Powertrain:
- CR-V B20b cylinder block
- Integra Type-R B18c5 cylinder head
- Integra Type-R B18c5 Intake and throttle body
- 550 cc Bosch injectors
- AEM fuel rail and adjustable fuel pressure regulator
- DC Sports 4 into 1 Ceramic coated header
- Test pipe
- Integra Type-R complete exhaust
- Short ram intake with K&N filter
- Full aluminium radiator
- Slim fan
- NGK bkr7e spark plugs
- Hondata s300 ECU
- Wideband oxygen sensor
- Flexfuel (will run on E85, 93 octane, or any mix of both)
