Radio loses power, shuts off at low rpms
Old Jun 5, 2017 | 04:52 AM
solowiej's Avatar
Default Radio loses power, shuts off at low rpms
Weird issue with my 92 EG (VX): My stereo (aftermarket Kenwood, been working for years) slowly fades out until it turns itself off. It comes back on at high rpms, sometimes associated with hitting a bump. I put a spare regulator on the alternator because I happened to have one. Still the same though. No battery dash light is coming on.
Now I'm thinking it's a loose ground somewhere. Can anybody point me in the right direction to find the main ground points?
Thank you!
Sean
Old Jun 5, 2017 | 11:31 AM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Radio loses power, shuts off at low rpms
Your alternator could just not be putting out enough juice. Car off, all load off, use a voltmeter to test voltage across the battery terminals. It should be around 12v. Start the car, leave all load off, test voltage across the terminals again. It should be around 14v. Turn on all load (high beams, stereo, air conditioning) and it should still be near 14. Alternatively, just drive to your local Advance or Autozone and ask them to test the battery and alternator for you.
Old Jun 12, 2017 | 06:41 PM
solowiej's Avatar
Thanks, NotAR. Alternator / Regulator are testing out fine. I pulled the head unit and it's something going on in there. Re-taped some wires, everything seems to be working now but we'll see. Possibly a bad ground somewhere?
When I get in/out of the car and touch the body I constantly get shocks. Is this symptomatic of bad grounding or just the high dry climate of New Mexico?
Sean
Old Jun 13, 2017 | 02:50 AM
NVturbo's Avatar
O.G. triple O.G.
Sean
Are you soldering the connections for the headunit?
You definitely have a bad ground somewhere in the car. I 'm betting you have an amp as well.
Old Jun 13, 2017 | 05:56 AM
solowiej's Avatar
I haven't soldered them yet, but that's next if it fails again. And on your advice, I will now focus on cleaning up all the grounds.
You think I have an audio amp somewhere in addition to the head unit? I haven't seen one anywhere...
Thanks,
Sean
renzis00
Nov 5, 2012 04:29 AM
Choy
20
Jul 20, 2009 07:11 AM
97dc2
Mar 8, 2005 11:31 AM
daver
Sep 19, 2003 10:39 PM
ck279
Oct 12, 2001 05:27 PM
