Help: STD Swapped to DOHC ZC Swapped to D16A6
Old Jun 4, 2017 | 10:05 AM
GameBoyeas's Avatar
Default Help: STD Swapped to DOHC ZC Swapped to D16A6
HELP
Information:
The Honda I'm working on is a 1990 Honda Civic STD EF. It originally had the D15B2 engine which was swapped out for the DOHC ZC engine. I sent out the harness to have it converted from DPFI to MPFI and to have it support the DOHC ZC engine. I've recently swapped to a rebuilt D16A6.
Problem:
The original harness has been converted to have two external wires which I believe are cam sensor wires; What's done is described fairly well in this thread: Where Does DOCH ZC ( 3rd. gen.) cam sensor plug into the ECU? | HondaSwap
I need to convert what I have to the round 7 - wire connector so that my engine can run. What do I hook up where?
Here's what I have:
Old Jun 5, 2017 | 05:25 AM
jlicrx's Avatar
Default Re: Help: STD Swapped to DOHC ZC Swapped to D16A6
I notice that you have an aftermarket distributor which has a yellow/green igniter wire instead of the OEM white
YungICY
Mar 15, 2012 06:40 PM
HondaHemi
Apr 25, 2006 02:36 PM
SC-MK1
May 22, 2005 08:51 PM
gregv
Sep 11, 2002 03:24 AM
