all DOHC B series owners
Old Nov 10, 2002 | 03:33 PM
stockegsix's Avatar
Default all DOHC B series owners
what motor and tranny are you using? and when your going 80MPH in 5th gear, what RPM are you guys on.
Old Nov 10, 2002 | 03:37 PM
IM ALL BOB's Avatar
Default Re: all DOHC B series owners (zzZZzzleeperCX)
4krpms @ 80mph w/ 195/50/15 tires give or take 100-200rpms since the stock tach shows higher compared to my 10FOOT high Autometer tach basically gsr tranny on a ls motor.. when I had the ls tranny I was hitting I believe 3500@80mph on 195/50/15 tires or so
[Modified by IM ALL BOB, 12:52 PM 11/11/2002]
Old Nov 10, 2002 | 03:44 PM
JDMb18civic's Avatar
Default Re: all DOHC B series owners (IM ALL BOB)
b18c engine
itr tranny
when im at 80mph its at 4500rpm
Old Nov 10, 2002 | 03:48 PM
BERT-O's Avatar
Default Re: all DOHC B series owners (JDMb18civic)
ITR tranny with 195/45r15 doing at 4700 rpm @ 80 mph
Old Nov 10, 2002 | 04:16 PM
Rratedcivichatch's Avatar
Default Re: all DOHC B series owners (SANBST)
itr, cant remeber exactly what im at , but somehwere in the mid 4k rpms on 205 azenis.
Old Nov 10, 2002 | 04:38 PM
mugen76's Avatar
Default Re: all DOHC B series owners (Rratedcivichatch)
b16b with b16b tranny... close to 5k rpm at 80mph
Old Nov 10, 2002 | 04:42 PM
jdmb16ahybrid's Avatar
Default Re: all DOHC B series owners (mugen76)
b16a motor b16a tranny - 4800 i believe
Old Nov 10, 2002 | 05:58 PM
Default Re: all DOHC B series owners (C5_ALLMOTOR)
u got a gsr manifold? lol i dont get it... why 4400rpm vtec engagment? chip ?
Old Nov 10, 2002 | 06:07 PM
ill phil's Avatar
B16 w/ y21. If I remember correctly somewhere around 4600 RPM or so. I'll let ya know for sure when I go out later
Old Nov 10, 2002 | 06:18 PM
stockegsix's Avatar
damn yO thats freakin' high. reason i wanna know is coz i'm at 4k @ 80 mhp
Old Nov 10, 2002 | 07:08 PM
W.Zero's Avatar
b16 head
b18c1 block
gsr tranny
around 4k @ 80mph
Old Nov 10, 2002 | 07:24 PM
b00stn's Avatar
Default Re: all DOHC B series owners (W.ZeroB18C1T)
5k at 80mph is what kept me away from wanting to swap to ITR gears. I drive around 80 everyday on the highway.
Old Nov 10, 2002 | 07:26 PM
97hb's Avatar
3500rpm @ 80mph in 5th gear(s80 LS tranny). Automatic LS tranny does 3250rpm @ 80mph.
Old Nov 11, 2002 | 05:49 AM
VTECVillain's Avatar
Default Re: all DOHC B series owners (97hb)
B18C1 motor/tranny, 195/50/15 tires = 4K @ 80mph in 5th grear.
Old Nov 11, 2002 | 06:10 AM
Kp_VtekNiks's Avatar
im at about 5k at 80mph, i got 99 sc4. 4k at 80mph is normal for a gsr tranny
Old Nov 11, 2002 | 07:22 AM
jas0n's Avatar
Please don't hurt me!
Default Re: all DOHC B series owners (Kp_VtekNiks)
with my d series vx i hit 100 in 3rd gear
i dunno bout my gsr some where in 4k area
Old Nov 11, 2002 | 07:37 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: all DOHC B series owners (couter)
For those of you guys listing tires size, thanks - it does makeka difference when we're talking mph and rpm in 5th gear.
I'll have to double check mine, but here's how it should break down:
99-00 Civic Si, USDM and pre-'98 spec JDM ITR, CTR, Del Sol VTEC, second-gen JDM B16A hydro, and the '98 Spec ITR ALL have the exact same 5th gear cruising rpm.
Now before anyone jumps my **** and says "but the '98 spec ITR has the 4.78 FD in it!" true it does, but it also has the taller 4th and 5th gears from the GS-R tranny and the 4.78 FD combined with the .787 5th equals the exact same cruising rpm in 5th as the 4.400 FD and the .848 ITR 5th equals nearly identical 5th gear cruising.
The USDM and JDM Integra GS-R trannies will have a lower cruising rpm in 5th because of the 4.400Fd and the .787 5th gear.
JDM S1/J1 cable trannies will have an even higher cruising rpm in 5th because they have the same 4.400FD but also have a shorter 5th gear - forgot the spec but I'm sure their 5th gear is shorter (higher number) than the .848 ITR/Civic Si 5th gear.
LS trannies will have the lowest crusing rpm of any stock tranny because of the 4.26FD and the tall-*** (lower numer) 5th gear too.
Tires size and tachs will vary, so really the best way to judge all of this is to check a gearing chart - I don't have the link handy, but I'm sure someone will chime in shirtly with it. It was on the autocrossing.com site.
Old Nov 11, 2002 | 11:15 AM
ejprimo's Avatar
Default Re: all DOHC B series owners (B18C5-EH2)
jdm b16a
y21 transmission
around 4500 rpm @ 80mph.
husker26
Dec 14, 2006 03:26 PM
Slowboy!
Dec 8, 2005 11:09 AM
Jay Blazed
Aug 11, 2005 04:47 AM
sinfultrends
43
Aug 19, 2004 11:31 PM
dizzbetim
Jan 8, 2002 06:55 PM
