P73 vs P72 AC Mount
Old May 30, 2017 | 01:25 PM
bambbrose's Avatar
Default P73 vs P72 AC Mount
In searching for an AC mount to put AC back into my 98 R, I noticed that the P72 mount (USDM GSR) is substantially lighter/less beefy than the USDM ITR P73 mount, which is a solid cast iron piece.
See pics.
Does anybody know why, the ITR which is supposedly built for lightweight use, would use a much heavier mount?
Is there any reason (block rigidity, mount rigidity, etc.) to use the P73 mount?
Old May 30, 2017 | 06:31 PM
hakjai's Avatar
Default Re: P73 vs P72 AC Mount
Subscribed I'm looking into doing this too later down the road. Once I get her closer to where I want her to be. Please keep us posted if you find out elsewhere.
Old May 31, 2017 | 04:54 AM
chad's Avatar
Moderator
BECAUSE AC was an OPTION on the TYPE R......
gsr came standard......
and as you stated the type r was suppose to be a race car......sooooo....if you are putting ac on why does it matter if the bracket has a few more pounds
Old May 31, 2017 | 06:51 AM
bambbrose's Avatar
I guess the question is more, why would Honda go through the effort to cast a new, heavier, part for the ITR when the lighter P72 part was already available? Is their a structural purpose? Does the idler pulley sit different and the mount need strength to support it at 8500 RPM?
Just curious if anybody has the scoop on this from years of ITR research.
Old Jun 2, 2017 | 05:26 PM
Klasse's Avatar
Can't really help with your question but in semi relevant info the jdm ac bracket is iron, the non ac is the alloy one. But apparently the non ac can be drilled/tapped/ground down to attach ac
Old Jun 4, 2017 | 09:08 PM
hakjai's Avatar
Hey bambrose I came across this part listing from icb. According to the item description there were 3 variations of this part. Maybe the R's got the full aluminum which would make sense.
Full Cast Iron = 7lbs.
Hollowed Cast Iron = 6lbs.
Full Aluminum Mount = 2.4lbs
JDM Integra/Honda B-Series Aluminum AC Mount
Old Jun 5, 2017 | 06:10 AM
bambbrose's Avatar
Correct, however most of the ITR (UDSM and JDM swaps) have the full cast iron part. I'm not sure what exactly the aluminum came on from the factory, be it the EK9 or the AC-less ITR motors. I find it interesting that honda would even make the full cast iron part when the hollowed part is lighter and readily available. I'm sure there is a reason that only the engineers would know.
Old Jun 5, 2017 | 08:34 AM
94eg!'s Avatar
#1 Super Guy
Loved
It appears the Aluminum bracket is made for a different compressor than the two Iron options (the 4 bolt holes align differently). The ICB listing says it will works in place of the Del Sol or CRV mount for swaps. It appears to be designed for a Sanden scroll compressor found on EG/EK Civics.....not the Denso piston compressor found on US-market Integras.
y0whuddupb
May 28, 2007 03:29 PM
rasinhell
Mar 18, 2005 08:45 AM
CaptivaBlue
Mar 3, 2005 03:39 PM
mingchi69
Aug 13, 2003 11:15 AM
