Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
D17A Swap into 2004 Civic Lx. Vtec ECU Pinout?
Old May 29, 2017 | 05:21 PM
Nisif's Avatar
Default D17A Swap into 2004 Civic Lx. Vtec ECU Pinout?
Hey All,
I am in the process of swapping a JDM D17A engine into a 2004 Civic LX. The original engine is a D17A1 non vtec engine. I already have the Vtec ECU to control the new D17A Vtec engine. The only difference I see is the addition of the vtec solenoid on the new D17A engine. Does anyone have the ecu pinouts for a 2004 Civic ECU? From what I can tell I only need to add 1 wire from the ecu to the vtec solenoid. I just need to know where to tap in the new wire. I do not have the D17a engine harness so I'll need to use the original wiring harness.
If there is anything else to note any suggestions are welcome. I'm aware I'll need to sync the immobilizer to the new Vtec Ecu in order to start the car. Thank You.
Old May 30, 2017 | 11:24 AM
Nisif's Avatar
Default Re: D17A Swap into 2004 Civic Lx. Vtec ECU Pinout?
Not much action in this subforum...
Old Apr 30, 2024 | 08:03 PM
dopedevin's Avatar
Icon4 Re: D17A Swap into 2004 Civic Lx. Vtec ECU Pinout?
did you ever find out which pin it is? because I'm having the same issue in my 2004 Honda civic lx I have a d17a2 but it doesn't have a wire on the harness for the solenoid.
Bacondoggy
Oct 8, 2009 04:14 PM
Dave62684
Aug 12, 2009 10:22 PM
iceman7329
Apr 25, 2007 10:08 PM
tiresmoke
Jan 3, 2005 08:36 PM
