1994 Honda Civic ex d16z6 please help!
Old May 26, 2017 | 07:08 PM
MattNicholson11's Avatar
Default 1994 Honda Civic ex d16z6 please help!
Okay I'm new to this site. My names Matt I just picked up a Honda Civic ex with a d16z6. This is my first civic. So I have a problem. The car starts sometimes but sounds like it's not on all 4 cylinders. It's getting fuel. I took out the spark plugs and put a metal brake cable down all the cylinders and #2 wasn't moving at all. What does that mean and what do I have to do to fix it!? Please help!
Old May 30, 2017 | 05:34 PM
egcivic775's Avatar
Default Re: 1994 Honda Civic ex d16z6 please help!
try and get a flashlight shining down the spark plug hole and turn the motor over by hand and try and see the piston moving. or run a compression test.
Old May 30, 2017 | 06:43 PM
I snapped a rod on #2 bottom end is trashed just got done with a d16y8 swap biggest pain in the ***. Thanks for the reply tho. My z6 head is still in great shape and I had a bigger cam on that could I switch out the heads ?
Old May 31, 2017 | 06:21 AM
egcivic775's Avatar
Yes you can I don't know all that's involved but just search y8 block with z6 head.
you might be able to just change the cam out
Old Jun 3, 2017 | 03:43 AM
Okay now I'm having another problem if you don't mind helping.. so the car started to shut off while I was driving and would start run for a sec then shut off. I'm using my distributor from my old motor on it it only mounts up with one bolt. Could that be the problem? Ecu? I tried the ignition switch I got a whole new steering column with it and still the same
Old Jun 3, 2017 | 04:30 PM
egcivic775's Avatar
There should be more than one bolt. But try and hold it into the cam and have someone start the car and see if it helps
eoris__ej1
Jun 26, 2013 12:09 PM
Jap_Spec_Imports
Oct 14, 2008 04:19 PM
djenk_85
Jan 20, 2005 04:54 PM
Limited S.L.I.P.
Nov 3, 2003 08:42 AM
