Crx 88-91 ect problem
Hi guys its good be in the HT I have a crx in India which I got it from my friend the wiring was a mess as some local mechs had cut the wires of ect radiator fan and the car was not in a running condition but some how I managed to make it start but I want to know how the ect works according to ecu pin outs b4 is a radiator fan relay connection is it a +12v ? or ground ? And which is the ect wire which goes to ecu and fan please help me out with this
here are the wiring diagrams for the cooling fan - one for car without A/C and one for car with A/C
the cooling fan switch is on the back of the block next to the oil filter - has a 2-wire connector with round black rubber boot - wire colors are yellow with green stripe and solid black
the radiator fan relay is located on the passenger side inner fender panel behind the headlight and battery
the A/C relays for the condenser fan and compressor are located on the passenger side end of the radiator core support
JDMsalinger
Aug 12, 2013 06:04 AM
AgentJam
Jul 1, 2005 05:23 AM
