97CivicEX jdmb16a CKF bypass
Old May 22, 2017 | 02:34 PM
98EGY8's Avatar
10 Year Member
Default 97CivicEX jdmb16a CKF bypass
we swapped a jdm b16a into my brothers civic, obd2a, usdm p72 gsr ecu, 1 code CKF because of jdm oil pump
we followed the guide here
.:FFS TechNet : CKF Bypass Trick :.
and we cant get cel to go away, bypass gets rid of CKF but then we get camshaft sensor a no signal code,
we also tried the "updated version" cutting the blue/red stripe and white/red stripe wires, still get camshaft sensor cel
i dont get it, i used this trick in my 98 EX with b18c swap to pass emissions and it took me like 5 mins to do
Old May 27, 2017 | 01:49 PM
98EGY8's Avatar
10 Year Member
Default Re: 97CivicEX jdmb16a CKF bypass
anyone have any idea? ive re-read the guide what feels like 100 times,re-checked everything, we followed it to the t, right now were runnin b16 on hondata s300 just fine but we need to pass emissions
Old Jun 11, 2017 | 12:24 PM
98EGY8's Avatar
10 Year Member
alright so were connecting a ckf sensor to the ckf plug and mounting it by the intake cam gear, then attaching a small bracket with teeth to the cam gear via cam gear bolt, to try and simulate the crank gear, so the ckf can pick that signal up
massasshadows
Oct 16, 2013 01:36 AM
ej2civoke
Mar 14, 2010 04:47 PM
naterpatater77
16
Jun 25, 2009 05:06 AM
juanchoenuncrx
Oct 21, 2007 12:42 PM
