Honda CR-V & Element 2WD & 4WD Element & CR-V
CR-V 2001 Hazard Lights not working - Turn Signals work fine.
Old May 20, 2017 | 06:08 AM
Doc Days's Avatar
Default CR-V 2001 Hazard Lights not working - Turn Signals work fine.
CR-V 2001 Hazard Lights not working - Turn Signals work fine. Any suggestions? Is there a separate Relay for the Hazard lights? If yes, where is the relay? Thanks.
Old May 29, 2017 | 06:40 PM
ARMED's Avatar
Default Re: CR-V 2001 Hazard Lights not working - Turn Signals work fine.
fuse?
Old Jun 1, 2017 | 09:05 AM
Collsj's Avatar
I agree with Armed to check the fuse diagram to see if they are on the same or separate circuits. The switch for the hazard lights could be bad also, or its flasher if its separate from the signal flashers
ula1234
Dec 30, 2016 12:48 PM
fourblades
May 7, 2015 09:18 PM
ERKK
10
Dec 15, 2010 07:48 AM
asianalbutt
Feb 20, 2007 12:34 PM
