92 ACCORD Electrical issue with gauges
Ok HT this is my second post and need help.
Things that don't work on my dash,
all gauges
All illumination lights (dome light and door lights works)
Shift selector by gauges
Radio
clock
Turn signals inside and out both side markers and turn signals on bumper
hazards
Glove box light
passenger mirror light
What does work :
key in chimer
Headlight on chimer
Brake lights
Headlights
Wipers
Sun roof
Things I tested
All fuses using visual inspection, I do not have a test light but I replaced all obvious fuses labeled as things like "day lights" "radio" "turn signals" etc both in footwell and under hood
dimmer switch plug only receives about 1 volt using volt meter
Dimmer switch it self does not change resistance when changing dial used volt meter to test
Checked radio fuse
Not tested
Cruise control
My conclusions
Probably not the instrument cluster because the headlights indicator works the chimers work sun roof works all that routes through the cluster I believe.
Could be the integrated control unit or the multiplex, all though I did not see it on the wiring diagram I feel the the radio the intruments and the clock route through the ICU but everyone that has a problem with the dome light and door switch and wipers... Etc so I do not know...
Could be the fuse box either loose connection to the fuse connector
Could be a bad fuse connector
Could be a ground Loose
Could be a burnt wire in the wiring harness somewhere
There is a lot of possibilities and very little money to test. So what are the most likely problems down to the least likely?
Or any other ideas too?
Thank you
all gauges
Radio
clock
hazards
Glove box light
What does work :
key in chimer
Headlight on chimer
Brake lights
Headlights
Wipers
Sun roof
Things I tested
Checked radio fuse
Not tested
Cruise control
My conclusions
Thank you
Could be the main ground as I did take off the battery multiple times during repairs.
It does have an aftermarket alarm in it a venom I believe but It has been installed pretty much day one. The guy I bought the car from knew the guy he got it from. The alarm has only caused a no start problem as it is tied into the ignition and it has a kill switch.
The ignition switch has been very loose for awhile now, as I can start the car and remove the key with the car running, I do have an original key though and it is very rounded off, could be the key or the switch or both. It's not a chip key.
Is there anyway to test the ignition switch? Electrically with volt meter or physical inspection?
I did run across someone that had an ignition switch that was always clocked one slot to far so stage I was always clocked to stage II so stage III was never intiated. Or something like that
accord99power
Jun 16, 2008 05:39 AM
prelude1897
Apr 27, 2005 11:09 AM
mister_r0b
Jul 16, 2004 10:42 AM
