engine fans not turning on
Old May 18, 2017 | 06:16 PM
j3rmit's Avatar
Default engine fans not turning on
98 Honda Accord EX, 4cyl, 4 door.
I have replaced the thermostat, fan switch on the thermostat housing, and the relays are still in working condition, but the fans will not turn on unless the AC is turned on. The temperature gauge shoots all the way to the red when stopped at a light. The new fan switch was working about 2 weeks ago, but recently stopped.
Old Jun 1, 2017 | 03:42 PM
Fullcirclexpw's Avatar
Default Re: engine fans not turning on
First off, how's your coolant levels? Topped off and bled? How's your radiator cap, have you witnessed coolant travel back and forth from overflow recently? Ever? Also check if it is actually overheating, don't just assume because a gauge says hot that it is hot. Do both rad hoses feel relatively similar after a drive? I could go on forever but start with the basics. Then get back with that info
rriznyk
Jun 19, 2014 02:42 AM
dhonda00
Jun 11, 2013 04:14 PM
Shade93
Apr 13, 2010 01:15 PM
Transport
Aug 7, 2008 07:12 PM
dawalude
Jul 23, 2004 11:41 PM
