Transmission & Drivetrain Gearboxes, Differentials, Clutches
Sticking 02 Accord Clutch
Old May 18, 2017 | 09:52 AM
MillerAcc's Avatar
Default Sticking 02 Accord Clutch
Replaced: Timing and water pump, adjusted tps, transaxle, clutch assembly, slave cylinder, flywheel, clutch kit(includes disk, pressure plate, and release bearing), clutch slave cylinder, and throttle body gasket! STILL STICKING!!!!!! Only in 1st and reverse! Sticks to the floor without even pushing it all the way to the floor. When it stick it will not release unles I force it up by lifting it with my foot and won't let it out of gear until I do and kills the motor!
Old May 18, 2017 | 10:21 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Sticking 02 Accord Clutch
You have air in the clutch line. Bleed it again.
Brandoncd5
May 31, 2015 09:24 AM
SlowCD5
Nov 9, 2013 02:14 PM
vodkaTM
Dec 29, 2009 06:06 AM
JFG Kevin
Apr 12, 2006 01:56 AM
rodnshaunna
Jun 30, 2005 02:11 PM
