02 honda accord se
Old May 16, 2017 | 05:39 PM
fquint74's Avatar
Default 02 honda accord se
passanger side leaking from boot area Whaat can i do to fix
Old May 17, 2017 | 06:38 AM
user456101's Avatar
Default Re: 02 honda accord se
If you mean that there is water inside the car on the passenger side, where the passengers feet go, then there are a few possibilities. If it has a sunroof, it might have a drain line for the sunroof area plugged or the drain line is disconnected. See this video
. If it is not that it is probably either the AC evaporator drain has become plugged or has come out of its fitting in the floor, or the heater core is leaking. If it doesn't have any smell and you are sure it is just water, it is the AC drain is plugged. See this video
If it smells like freon/anti-freeze then it is the heater core leaking and you either have to repair or replace the heater core or do without heat and re-route the coolant lines. If it is the heater core it is very difficult to fix because the whole dash has to be removed and it is a monster job. You can just re-route the coolant lines under the hood to bypass the heater core. There are lots of videos on how to do this on YouTube.
vaguy
Mar 12, 2018 07:41 PM
Cg_j30a
Oct 28, 2017 12:36 PM
NicoAnn94
Oct 30, 2013 02:51 PM
96AccordMD
Jun 16, 2009 10:38 AM
yaoming315
May 8, 2007 11:55 AM
