Cabin fan works at times then doesn't.
they all run off of the same blower electric fan under the glove box. is the air pressure weak? if so maybe blower needs replaced but yes check relay/ fuses and all connections wiring for breaks loose connections, bad relays etc. try replacing relay in fuse panel
97civicowner
34
Aug 27, 2018 06:09 PM
FLCivic
Dec 18, 2007 04:37 PM
