CRX OBD0 to OBD1 check engine light wont flash codes
1990 CRX SI swapped with B20Z jumper harness is a Rywire with a OBD0 to OBD1 distributor jumper harness using a stock P28 ECU. The check engine light is on but when I ground D4 wire the check engine light wont flash I do get a 4.8v reading from the wire but nothing happens when I ground it. Can anyone help me with this issue?
Yup blue wire on the rywire harness D4. The check engine light is on but when I ground D4 does not flash just stays on.
could be a solid cel code - Code 0.
These are often resolved with checking grounds.
Especially common with disconnected or dirty thermostat housing grounds.
Yeah I didnt know that the ECU was chipped until I opened it up. Now im guessing the chip also has launch control and that is why I cant rev past 4500RPM because Im running a cable speed sensor.
IF I get a new chip created without launch control what else would I need to ask for just to make sure that I can get the codes flashed through the check engine light.
Nothing really, the only thing that will cause a solid cell on a chipped ecu is either a bad solder/component install job, or a bad burn.
I don't see why launch control has anything to do with the cable speedo. ECU still gets the same pulses.
Can you explain?
Can you explain?
It's not even launch control, it's the ecu running in limp mode, and your are correct, the ecu still receives speed input from the instrument cluster.
So over the weekend I cut the jumper J1 and tried to started the car but now when the car starts it idles at less that 200-500rpm and dies after about 40sec when I try to give it some gas it revs up but bogs out and will die. Only code I get is 41 Heater O2. Im waiting on a new chip from Clubbedindustries.
No I did not
engine is a stock b20b with knock sensor and injectors im using the stock d16 that was on the CRX. The ECU was purchased from ebay.
n*werk
24
Feb 26, 2009 06:06 AM
UndergroundTuning
Dec 29, 2008 02:58 AM
cor4ey
Dec 20, 2008 12:42 PM
91highryda
Oct 6, 2007 08:24 AM
