Brake Hardline Replacement - 5th gen
Old May 9, 2017 | 08:52 AM
19Accord97's Avatar
Icon7 Brake Hardline Replacement - 5th gen
The hardline underneath the drivers seat on my 97 LX (Rear drums - no ABS) failed and emptied most of the brake fluid out of the car. I plan on getting stainless steel lines for all four corners but as far as the hardlines go, do they sell pre-bent lines with fittings? I don't have any experience with brake line replacement or whatnot so the easier the better! If not, is it relatively easy to bend all the tubing myself or will I be needing to drop things like the fuel take to get to some of it?
Thanks!
Old May 9, 2017 | 10:13 AM
19Accord97's Avatar
Default Re: Brake Hardline Replacement - 5th gen
So it looks like #9 and #12 are the two lines I need. Ouch....not cheap
https://www.hondaautomotiveparts.com...)&vinsrch=null
Are the fuel lines made of the same material as the brake lines? If so, I am guessing they are probably about rusted out as well..... ugh
Old May 9, 2017 | 03:40 PM
MAD_MIKE's Avatar
MM Gruppe B
Easiest is to purchase the replacement lines, they will fit properly.
If you want to try to save yourself money, purchase some NiCopp line, a bender, and flare tool. Most steel line is a PITA to flare without a hydraulic flare tool.
Old May 11, 2017 | 10:09 AM
19Accord97's Avatar
well bummer. I gotta take some time tonight or tomorrow and get the lines off.... hopefully it isn't too hard.
Another guy suggested taking the hard lines to someone and have them copy them. We shall see.
bw77
May 31, 2015 03:04 AM
lurchy
Dec 22, 2014 07:58 PM
thompson4908
Jun 6, 2011 05:56 AM
JDM BB2
Sep 10, 2003 03:27 PM
