d4 light blinks on my 96 accord
my car d4 light kept blinking for days..after even after the gear switch has bn serviced. my speedometer malfunctions at same time. does it have anything to do with the speed sensor? when the malfunction starts the car struggles to move. kindly advise
Look under your glove box door, there should be a single two wire blue connector.
Jumper it with a wire.
Turn ignition to II(ON)
Watch the D4 light for stored codes.
Record them and report back here.
You may also use an OBDII scanner/code reader to retrieve codes, but the transmission is the same type from 90-97 in four cylinder PGM-FI cars.
