Need troubleshooting and upgrade help
Old May 5, 2017 | 01:48 PM
K3rm1tTh3Fr0g's Avatar
Default Need troubleshooting and upgrade help
Hello!
Seeing as this is my first post I would like to thank all of the members on here for your help. I recently bought a 2001 Integra with 104,000 miles on it. I got a good deal and although there are some problems with it I think it was well worth what I paid. However there have been a few issues that I need some help with. Firstly I need a new muffler, the current muffler is aftermarket and has had some bad impacts and damage because of the car being lowered, it has two somewhat large holes on the top. The muffler is also sagging a good amount so any muffler I buy should include mounting hardware unless I buy it by itself. On the bright side, the pipe connecting to the muffler seems to be fine it is just the muffler itself that needs to be replaced. I would love a few suggestions and links to some good budget mufflers, the louder the better haha. Sadly I am not 100% sure of the exact sizes of specs of what I need, I suppose that's why I came here. There will be some pictures down below of the muffler and the surrounding piping and mounting hardware.
The second issue I am having is with my radiator fans, the fans connecting to the radiator only begin to turn when the AC is turned on, at which time they both begin to spin. There lack of spinning was brought to my attention by an employee at Grease Monkey, he said he used a multi-meter to check and there was no power going to the fan. Additionally he said that it was most likely a bad relay and that I can swap in another relay from a different part of the car to test it. The trouble is, I can't find the relay and I don't
want to make anything worse. Any ideas or suggestions would be super helpful.
Last edited by K3rm1tTh3Fr0g; May 5, 2017 at 01:49 PM. Reason: Had to upload pictures.
Old May 5, 2017 | 02:05 PM
CRazy-V's Avatar
Default Re: Need troubleshooting and upgrade help
any muffler will work i used to use a muffler made by DNA Motorsports and it had a good tone to it but was just too loud.
and as far as the fans as much as it can be the relay it can also be the temp sensor on the head to test the fan you can unplug the sensor and loop it with a paper clip to check and see if the fan kicks on...
Old May 5, 2017 | 02:07 PM
both of the fans spin when when I turn on AC so it's not a problem of broken fans I think.
punksz6
Feb 8, 2008 11:11 AM
megaman096
14
Nov 29, 2004 06:21 PM
steve_s
Jan 19, 2003 04:59 PM
