Unhooked battery/transmission jerks and slips
Old May 3, 2017 | 06:56 PM
Dkntwigg's Avatar
Default Unhooked battery/transmission jerks and slips
Replaced rear transmission mount (hydraulic) I unhooked battery for several hours. After I finished installing mount , I drove car and transmission slipped really bad going into all gears , if you leave off gas it goes into gear with a jerk ?
Old May 3, 2017 | 10:41 PM
holmesnmanny's Avatar
Default Re: Unhooked battery/transmission jerks and slips
Did you reattach the vacuum hose to the mount ?
Old May 4, 2017 | 12:30 PM
Dkntwigg's Avatar
Yes I did, I figured it out . It was the shift control valve under the battery box. I lifted the tranny to high and damaged the solenoid . I replaced it off an old transmission I had and it ran perfect . Thank you
acmoc
27
Jan 7, 2009 03:26 AM
Stinkalope
May 31, 2001 05:32 AM
