1998 Honda Accord Ignition Switch Problem
No, it's not like trying to learn how to steal a Honda. I don't care about any other Hondas than mine. I don't even have any idea what cars have this feature (and really couldn't care).
I have an old '98 Accord with 242K miles on it that I picked up two years ago. I drive 150 miles a day to work and home. It's perfect for that. I just don't want to spend any more money on an old commuter car than needed. That is why I want to bypass this feature on my car.
What is an "e-brake" code?
Haven't see the term "e-brake" code but there is a key number plate that shipped with your car as described in your owner's manual:
http://techinfo.honda.com/rjanisis/p...98O00067A.pdf#
][1,{%22name%22:%22Fit%22}]
There are number of blanks listed on eBay for not much cost, tho' no personal experience in making them work, and don't know whether you need the number when the locksmith cuts them; we're lucky to still have the three keys that came with my son's '99.
"E-brake" code is a code that can be entered using the emergency brake and a few steps. This code overrides the immobilizer system allowing the car to start without the "chip/immobilizer" working.
Depending on the dealership, some might give this code to you over the phone, others are going want you to come in a "prove" the car is yours. I've seen more than one 6th gen Accord (98-02) get "confused" and seem to forget the code - meaning the car just seems to forget the key. Once the e-brake code is used with the same key - its like the PCM wakes up and remembers the key again and everything goes back to working as it should....strange I know but again I have seen it happen.
- You will need a mechanical key that work the ignition lock cylinder.
- Get the "Immobilizer Brake Code" from the Honda Acura dealer; you would have to go to the dealer and show them proof of ownership of the vehicle, thus to very strict policy they will not give any information over the phone. The "Immobilizer Brake Code" is a five digit number. Each car has a different "Immobilizer Brake Code" since they are V.I.N(Vehicle Identification Number) specific.
- Turn the ignition switch to the ON position (II).
- Have the BRAKE CODE in front of you. To enter the first number of the BRAKE CODE, press and release the brake the same number of times as the first number in the BRAKE CODE. For example if the first number in the BRAKE CODE is a 2, press and release the brake 2 times.
- Turn the ignition switch to the LOCK position.
- Within 30 seconds, turn the ignition switch to the ON position (II). For example if the 2nd number in the BRAKE CODE is a 3, press and release the brake 3 times.
- Continue entering the BRAKE CODE as described above for the rest 3rd, 4th and 5th digits.
After entering the 5th number, the immobilizer indicator light on the dash should flash 5 times and then shut off. The car should now start. This procedure must be repeated each time you turn off the car for more than 10 minutes. The Immobilizer System indicator will remain on while the engine is running
Brum_RU
Dec 14, 2007 12:31 PM
