B18B in 90 crx Si
Old Nov 10, 2002 | 10:30 AM
95hbMatt's Avatar
Default B18B in 90 crx Si
I'll be swapping a 96 b18b into a 90 crx Si....any advice for me like what axles, mounts, etc...also i want to convert it to obd1...i have the ls obd1 ecu, will i need to get a obd0-obd1 harness to make it work or will i need to do more...?
also for the tranny...since the clutch actuator on the crx is for a cable tranny could i just simply swap out the pedal assembly and clutch master cylinder for a hydro tranny and it work...(i have the parts already, that's why i'm asking)...also what shift linkage can i use? any help would greatly be appreciated..thanks..
Old Nov 11, 2002 | 05:04 AM
95hbMatt's Avatar
Default Re: B18B in 90 crx Si (95hbMatt)
anybody....
Old Nov 11, 2002 | 06:41 AM
Jeff C's Avatar
Here is a good swap outline site...Hasport.
On the tranny, the easiest thing to do would be to find a cable one.
Isnt '96 obd2?
If you want to convert, yes you will need the conversion harness from Blown90hatcH.
Do a search for the conversion, there is several just from the past 2 weeks.
Old Nov 12, 2002 | 11:00 AM
95hbMatt's Avatar
Default Re: B18B in 90 crx Si (Jeff C)
so i wouldn't be able to use the hydro tranny?
and yes it's an obd2 motor and i want to convert it to obd1..
Old Nov 12, 2002 | 11:09 AM
Jeff C's Avatar
I didnt say that! I have heard that it is a lot of trouble. There are some people who have done this.
There are several threads covering the conversion too.
crxjarred
Jul 27, 2008 09:49 AM
foxxor
Jul 10, 2007 11:44 AM
kixcrx
Jan 15, 2007 08:43 PM
Eric_Hayward
Aug 28, 2006 11:29 AM
