Injector Dynamics - ID1300 fuel injectors - New In Box - for B / D / H Series
Old May 2, 2017 | 05:09 PM
bangin'gearz's Avatar
Default Injector Dynamics - ID1300 fuel injectors - New In Box - for B / D / H Series
These retail for over $900. Selling for $550 obo. Free USPS shipping in upper 48.
From the Injector Dynamics website:
The ID1300 is an all new injector, designed in ID1300was designed with alternative fuels in mind, and is the only performance injector available with all stainless internals. It is compatible with all kfuels, and will stand up to the corrosive nature of alcohol better than any injector on the market.
While the ID1300 was designed with an eye towards ethanol fueled engines, we have accounted for the occasional need to convert back to gasoline. The ID1300 has a minimum fuelmass compatible with gasoline use, and will provide exceptional idle and cruise behavior under these conditions. In addition to its multi-fuel capabilities, the compact body of the ID1300xallows fitment in 200+ applications, making it the most versatile injector in our lineup.
Basic Specifications
Nominal Flow Rate – 1340cc/min @ 3.0 Bar (43.5 psi) Using Iso Octane at 52 Degrees C (125 Degrees F)
Maximum Differential Fuel Pressure – 6.0 Bar (87.0 psi)
Fuel Compatibility – Compatible With All Known Fuels – (Designed Specifically for Alternative Fuels)
Electrical Connector – USCAR
bangin'gearz
Texas -OK -LA (Sales)
May 2, 2017 06:58 AM
spooolin
Oct 13, 2006 07:48 AM
PinkMaggit
Dec 22, 2005 05:24 PM
THEUSED
Oct 31, 2005 06:36 AM
