Acura front sway bar
i bought a 90 integra for oval track racing, we took it out last night, not too bad but a lot of body roll through the corner, we were looking at the car and there is no sway bar on the front? Did the 90 ls model come with one or can I get one off another car that will fit? And what about stiffer springs for the front, what Honda car would be a good choice to get a stiffer spring from? Must be a stock part or stock replacement part, per rules. Thanks
Previous owner may have felt it better for him without the swaybar. It certainly came with one.
Sway bars from ef and da chassis are interchangeable.
The da bar was the stiffest at 23mm but hollow.
There are 3 ef swaybars.
19mm solid from Civic sedan.
18mm solid from crx si.
17mm hollow from crx hf.
The 19mm is about equivalent to the da 23mm anyway because it's solid vs hollow.
So just try a da. Should be easy to find from the junkyard.
Official swaybar sizes and more detailed info.
https://honda-tech.com/forums/honda-...sizes-1894834/
88browncow
Jan 28, 2011 06:15 PM
fireant
14
Apr 12, 2006 11:43 AM
