Issues when swapping transmission
Old Apr 29, 2017 | 11:19 PM
bestofthe80s's Avatar
Default Issues when swapping transmission
Hey all,
I am in the middle of installing a rebuilt automatic transmission into our 01 accord sedan. I am following factory procedure and torquing to spec. One question I had is regarding the shift linkage. Where my shift linkage connects to the transmission. Is there any chance the linkage might need to be adjusted to row through the gears properly? Or should I not worry about it? Might there be small differences in cable length from car-to-car?
Old Apr 30, 2017 | 05:18 AM
poorman212's Avatar
Default Re: Issues when swapping transmission
Should be fine. Yes there might be some adjustment needed once all is said and done - just follow the proper procedure/
Old Apr 30, 2017 | 09:14 AM
Well, standard procedure mentions nothing in regards to adjusting shifter cable length... so..... hmmm.
Old Apr 30, 2017 | 10:13 AM
jollyhonda's Avatar
Unless something is bent or damaged, you should be fine on the shift cable.
Old May 1, 2017 | 02:23 PM
holmesnmanny's Avatar
If it's the same tranny why would you think you need to adjust something ?
Old May 9, 2017 | 12:54 AM
Edward Emmanuel's Avatar
Hello, can anyone help, am having trouble with my automatic transmission system, it will not change for 1 to 2 continuously, it moves for some time and disengages
Old May 9, 2017 | 12:56 AM
I have changed oil and flush the gear still nothing
Old Feb 11, 2022 | 08:38 PM
Michaelandjus's Avatar
I started with those same symptoms. I had to drive a few miles back and forth to work and it's got worse. I checked the codes and it appears it's solenoids. I'm going to try to clean the screens before I replace the solenoids
dansaleen_04
Oct 6, 2010 02:36 PM
EF9_RIDER37
11
Nov 11, 2009 11:34 AM
LOLO93PRELUDE
May 28, 2008 01:39 PM
FLyPimp
Apr 9, 2003 01:24 PM
